Apr 2, 2024 3:45 AM UTC
how to checkout the workspace object through api
I added the epm document to workspace though api, and i want to check out the added EPM document from the workspace.
this is my code
private void addToWorkspace(EPMDocument doc) {
try {
wt.fc.ReferenceFactory referencefactory = new wt.fc.ReferenceFactory();
wt.fc.WTReference wtreference = referencefactory.getReference(doc);
wt.epm.EPMDocument epm = (wt.epm.EPMDocument) wtreference.getObject();
System.out.println("epm-->"+epm);
wtreference = referencefactory.getReference("OR:wt.epm.workspaces.EPMWorkspace:1150900");
wt.epm.workspaces.EPMWorkspace workspace= (wt.epm.workspaces.EPMWorkspace) wtreference.getObject();
System.out.println("workspace-->"+workspace);
//Get the EPMDocument configuration
wt.epm.workspaces.EPMAsStoredConfigSpec asStored = wt.epm.workspaces.EPMAsStoredConfigSpec.newEPMAsStoredConfigSpec(epm);
wt.fc.QueryResult queryResult = wt.epm.structure.EPMStructureHelper.service.navigateReferencesToIteration(epm, null, true, asStored);
//To add to workspace, set some collection
wt.fc.collections.WTHashSet collection = new wt.fc.collections.WTHashSet();
collection.add(epm);
// Add to workspace
wt.epm.workspaces.EPMWorkspaceHelper.manager.addToWorkspace(workspace, collection);
//Get check out folder for the current user in the session
wt.folder.Folder checkoutFolder1 = wt.vc.wip.WorkInProgressHelper.service.getCheckoutFolder();
//Check out object
wt.vc.wip.CheckoutLink chklink1 = wt.vc.wip.WorkInProgressHelper.service.checkout(epm, checkoutFolder1, "Check out comment");
wt.epm.EPMDocument wrk1 = (wt.epm.EPMDocument) chklink1.getWorkingCopy();
} catch (WTException | WTPropertyVetoException e) {
e.printStackTrace();
 this is coming like this, i wanted to checkout from workspace
HelesicPetr
Apr 24, 2024 1:43 PM UTC
Hi @GS_10707985
Try to use follwoing workspace chekout method
public WTValuedMap checkout(EPMWorkspace var1, WTCollection var2) throws WTException
PetrH
Emeritus
Apr 5, 2024 5:58 AM UTC
Hello @GS_10707985,
Thank you for using PTC Community!
Did you get a chance to search our knowledge base?
There are several knowledge base articles around this topic. Please click on the above hyperlink and review if any of those articles help to answer your question.
Use your PTC.com username and password to login.
If a certain article helps, please post that article link here & mark it as a solution. It will surely help other users who may have a similar question.
Hope this helps.
Thanks & Regards,
Community Moderation Team.
HelesicPetr
Hi @GS_10707985
PetrH
