how to set the default navigation to part details tab
vganugapenta
11-Garnet
I have have navigated to the information page of a part and selected  the 'Structure' tab ->  and opened any part then it opens in a window with 'Structure' tab selection by default . Now I need to open the window with 'Details' tab selection.
Hi @vganugapenta,
This behavior is because of Client Stickiness. You can refer to "Client Side Stickiness" section in following help center document. There is a way to override the tabSetKey but that might not allow you to change the current behavior.
http://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=WCCG_UICust_InfoPages_InfoPages&action=show
Bhushan
