Hi all,
i've tried to call this servlet
POST /Windchill/servlet/odata/IE/InvokeIETask
with this body
"Task": "com/ptc/windchill/enterprise/report/ExecuteReportTemplate.xml",
"Params": [
"Name": "object_ref",
"Value": "wt.query.template.ReportTemplate:6852467828"
now I need to change the report criteria directly from the API. I tried to add a parameter but it doesn't seem to work.
For example (but it doesn't works)
"Params": [
"Name":"where",
"Value":"((Associated Part.Latest Iteration equals 1) AND (Part Master.Number in 1234))"
Where can I find documentation? what is the correct parameter?
