is there a api to create Change Notice through java code
is there any api to create Change Notice by setting custom template to it through java code in Windchill 13
Unfortunately there is no supported API other to do that. See https://www.ptc.com/en/support/article/CS174385
Probably you need to write your own class to copy the object. Or you could try to save as the object? https://www.ptc.com/en/support/article/CS59135
not sure if that would work.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
