is there any api to create Change task template throw code.
AR_9920456
is there any Api to create Change task template throw code in change notice.
Hello @AR_9920456,
Thank you for your question.
Your question appears to be well documented, however I'd like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
HelesicPetr
(To:AR_9920456)
Hi @AR_9920456
Why do you need the change task template?
Just create a Check Task and link it to a change notice.
PetrH
