java.lang.UnsupportedOperationException
CL_9966509
2-Explorer
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS08
PersistenceHelper.manager.delete();
객체 삭제 하면서 발생하는 에러.
INFO : wt.system.err wcadmin - wt.util.WTException: java.lang.UnsupportedOperat
ionException
INFO : wt.system.err wcadmin - ?? ??: java.lang.UnsupportedOperationException
INFO : wt.system.err wcadmin - at wt.fc.collections.UnmodifiableCollect
ions$UnmodifiableIterator.remove(UnmodifiableCollections.java:895)
INFO : wt.system.err wcadmin - at java.util.AbstractCollection.retainAl
l(AbstractCollection.java:410)
INFO : wt.system.err wcadmin - at wt.projmgmt.StandardProjMgmtService$3
.notifyVetoableMultiObjectEvent(StandardProjMgmtService.java:552)
INFO : wt.system.err wcadmin - at wt.events.StandardKeyedEventBranch.in
tDispatchEvent(StandardKeyedEventBranch.java:298)
INFO : wt.system.err wcadmin - at wt.events.StandardKeyedEventBranch.di
spatchVetoableMultiObjectEvent(StandardKeyedEventBranch.java:263)
TDT
(To:CL_9966509)
Hi @CL_9966509,
What are you trying to delete?
CL_9966509
2-Explorer
(To:TDT)
@GenAsPersistable(superClass=RevisionControlled.class,
interfaces={ FormatContentHolder.class},
properties={
RevisionControlled  obj delete
PersistanceHelper.manager.delete(obj);
error
