In Windchill 11.0 M030 version, since it is necessary to receive from other systems through interfaces, sample code related to the addition, deletion and modification of classification nodes and classification node attributes is required. After checking, I learned that in Windchill11.0 version, there is no supported API for direct operation.
Hi @铭周_10045792
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
The supported Apis are available starting 12.0 , see https://www.ptc.com/en/support/article/CS338403
