Could you please share me the process of Fixed account authentication configuration for navigate.
we have not configure windhill without SSL. Please share process.
Bhagyashree
In Thingworx :
In Windchill :
In Thingworx :
In Windchill :
I have done setting as mentione dby you but when i put below url it throw error while saving
(Starting Navigate 1.8) : Set "Test Connection URL"=http://<SERVER_NAME>/Windchill/servlet/WindchillAuthGW/wt.httpgw.HTTPServer/echo
so i have changed to http://<server_name>/Windchill so it save.
But now when i click validate service its failing i have attached log .Please let me know your comment
While saving ptc-windchill-integration-connector-proxy, it invokes ValidateConnection service of ptc-windchill-integration-connector. Please modify ptc-windchill-integration-connector firstly and make sure ValidateConnection service could execute successfully.
Also, make sure to enable the Dynamic Content check box.
Thank you all for your reply my IR service was not running due to which it not validating connection not its up.
Hi @bkulkarni.
If one of the previous replies answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
