Thingview widget duplicates "views" when loading new model
ehalvordsson
We are using the Thingview widget on a mashup and want to use the "Views" functionality. The function works fine with the first model (extracting the views from the Thingview, storing as infotable and then binding the list again to the "Views").
However, when we load a new model (changing "ProductToView") the previous views seem to stay in memory and the new views (from the new model) are added to the list. I do not think that this is due to my implementation (have tried many workarounds). The only thing that seems to work is to completely refresh the webpage.
Did anyone experience the same behaviour and is there any known workaround that actually resets the ThingView widget?
0 REPLIES 0
