https://www.ptc.com/pt/support/article/cs351650 This Article is old, and Thingworx Flow is no longer used in Thingworx Navigate 9.6 Installation.
After a couple of re-tries, below is the article I found to fix this issue.
https://www.ptc.com/en/support/article/CS357699?source=search
Indeed article is not applicable in this use case.
In order to investigate your issue further, could you please provide ..\ThingworxStorage\logs and ThingworxNavigate\IRLogs folders zipped ?
Kind regards.
