Hello everyone!
I am trying to figure out the best way to migrate product objects and its contents from one server (windchill 11) to another one (also windchill 11). What is the best way of accomplishing that?
The best way to migrate data from one Windchill to another existing Windchill would be to use Windchill Bulk Migrator
Other than WBM,
1. Generic Loaders: you would need to use Export/Import Framework and programme IXB loaders in Java
2. Use PLM connector Module if it is Creo data only.
