I have an excel list that came out of our ERP system (name and rev). I need to check rev level against Windchill. How do I get Windchill to take this list and fetch current latest rev level?
I would take your Excel list of numbers and make it a one line list that has a ";" in between each number and copy it to the Search area of Windchill. You must have Index searching turned off though. I think that there is a limit to the number of characters in one search though. You can have "*" in the search criteria as well. It is the Keyword search.
It would look like this:
12345;12367;12378;12456;12678 etc,etc.
Then you could export the list to Excel from Windchill and do some comparisons within Excel.
Thanks for the info Brian...since asking this question I went and talked with our SQL DB guy. Very simple search on his end got me the info needed.
Greg
