Adding requirement to a test case via cmd
AD_10334222
Hi, how can i add a requirement with command prompt to a created test case ? In other words, how to link a requirement to a test case ?
kjain2
(To:AD_10334222)
Hi @AD_10334222
You have to first find out what is the relationship field defined between Test Case and Requirement in your system. It could be Verifies or Validates or could be something else as well depending on how your system is being implemented.
After that you just need Test case ID and Requirement ID with you and need to write im editissue command for this.
Please go through below help page to get more details about this command:-
Windchill RVS Help (ptc.com)
Does this help? Feel free to ask if you have further questions.
PS: If this helps please mark this as an accepted solution so thread can be closed.
Vielen Dank / Many Thanks,
Kapil Jain
kjain2
(To:AD_10334222)
Hi @AD_10334222
Kapil Jain
