We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Hello Community,
One use case may be anyone can share his/her findings or any experience :-
Use Case:- Windchill RV&S Web GUI not working in Browser as it do opens but when we click on "Start Workflows and Documents Web Interface" it gives 401 error generally it should open a new tab with pop up window asking for username and password. Email Links are also not working because technically first they jump on browser and then launch Windchill RV&S.
Root Cause :- Browser Policies in our organizations are updated and what we got from policy team, "Integrity has basic authenticate/ authorization method by default and it needed to convert into Kerberos, Kerberos SSO, openIDConnect or SAML".
What i know so far don't know about SAML or openIDConnect, but Windchill RV&S do have Kerberos and Kerberos SSO mechanism. It's just more or less how to implement, because i haven't enabled this in past and no prior experience with Kerberos enablement.
I have tried some hit and trials in security.properties by adding two property mks.security.kerberosRealmName & mks.security.kdcAddress and after that setting mks.security.policy.scheme.default=windows_private,mksdomain_private because we do have SSL in place. But unfortunately didn't worked.
I am trying to enable Kerberos not Kerberos SSO for the moment because it requires other thing like keytab file and all. Or do i need keytab file for this as well ?
If anyone has any prior experience or any idea, feel free to come in comment section or PM me. I would be very grateful to have a conversion on this with anyone.
Cheers,
K. Jain
There's some info in the installation reference guide, but there's also this knowledge article, which you will no doubt find informative:
How to set up Windows/WindowsSSO Realms (Kerberos SSO) in Integrity
https://www.ptc.com/en/support/article/CS116568
It's pretty in-depth.
I would suggest opening a Support case, for assistance with this, if the knowledge article does not help you along.
Mike
