CLI with --project= option and revision number
pnone
8-Gravel
Hello Support,
in the CLI si viewproject --project="#p=/root_project/project.pj#s=sub-project/project.pj#d=dev_test"  how do I provide the sub-project revision number on the development path dev_test?
--projectRevision= is not allowed because --project= option is being used.
Eagerly waiting.
Thank you.
LLawton
(To:pnone)
Hello Pashan,
Then I don't understand the question because my example works and it does use projectRevision with the project option.
I have never seen this syntax in the CLI: "#p=/root_project/project.pj#s=sub-project/project.pj#d=dev_test", so I may be confused.
Have you tried the syntax I proposed, especially example #2?
If you want a specific checkpoint (project revision), you don't have to specify the devpath since it's already implied.
Sorry, that's all I have.
4 REPLIES 4
LLawton
(To:pnone)
I think you want the "--devpath" option.
From the example you provided, the command would be:
si viewproject --project="/root_project/sub-project/project.pj" --devpath=dev_test
You could also try:
si viewproject --project="/root_project/sub-project/project.pj" --projectRevision=1.3.1.5
In this example, your dev path started from main line checkpoint 1.3 and has a number of checkpoints
Notes:
- The two commands are not strictly equivalent depending on context, but I include them because you did mention projectRevision.
- No need for "#", and there is no distinction between project and sub-project in this case.
- You can type "si viewproject -?" for syntax and all options (true of any command).
pnone
8-Gravel
(To:LLawton)
Hello Laurent,
That will not work, because when you use --project= option then --projectRevision= will not be accepted. That's what my question was. When I use --project= option, then how do I mention the version number in the CLI for "si viewproject" command.
Hopefully my question is clear.
Thank you.
LLawton
(To:pnone)
Hello Pashan,
pnone
8-Gravel
(To:LLawton)
Hello Laurent,
You are right. It works as you mentioned.
Thank you.
Regards
