The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Solved the problem easily using this method - also can be used for other areas which have limited licences. The name to use in the opt file (ART_PLE in the example) can be found in the artisan.lic file
