Defining default drag-n-drop trace relationship
nborrerojr.
7-Bedrock
Could someone explain or point me to documentation that explains how to define what the default relationship is when a user does a drag-n-drop from one node to another?
KaelLizak
(To:nborrerojr.)
Hello Nolin,
Given that you are talking about nodes, I suspect you are talking about drag and drop from the context of the Integrity Document View. This suggests you are specifically talking about trace relationships. If that is the case, I believe CS128673 would be of use to you.
Kael
Kind Regards,
Kael Lizak
KaelLizak
(To:nborrerojr.)
Hello Nolin,
Kael
Kind Regards,
Kael Lizak
That's it! Perfect. Thank you.
