Defining default drag-n-drop trace relationship
Could someone explain or point me to documentation that explains how to define what the default relationship is when a user does a drag-n-drop from one node to another?
Hello Nolin,
Given that you are talking about nodes, I suspect you are talking about drag and drop from the context of the Integrity Document View. This suggests you are specifically talking about trace relationships. If that is the case, I believe CS128673 would be of use to you.
Kael
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
