We have at office both Integrity Client 10.8.0.8356 and Integrity Client 11.0.0.506 (see attached image)
Both versions have a 32 bit JRE in "C:\Temp\IntegrityClient10.8_2\jre" and respectively "C:\Temp\IntegrityClient11.0\jre"
If I overwrite the JRE folder with a 64-bit version of Java, is it all right or not ?
So the question is: do the PTC Integrity 11 and PTC Integrity 10.8 clients work with Java 64 bit runtime as well?
No, we only have 32-bit versions of the clients. If you overwrite the jre directory under IntegrityClient, your Integrity Client will not even start.
