I am extracting the descriptions of my Integrity test cases via web services (C#) and it works fine.
The only problem is that the parameters are not substituted, they are written as {{myParam}} within the text.
Is there a way to get the field contents with the real parameter values?
I know that your request is already a bit older. Hope this note still helps:
Please use "tm testcases" instead of "im" commands.
