How to best leverage a common set of legacy test steps.
byoung
I have several legacy protocols that use the same set of test steps. What is the best way in Integrity to leverage a common set of test steps across several test protocols without having to individually include each test step within a test case?
HI Bob,
what about another Test Case, where you link the Test Steps into?
And the Test Case then you share between the different tests where you need them? Give the test case a specific category, such as "Initializing Steps" to make clear that this is a "cover" test case.
(not tried by myself, just an idea ....)
Volker
HI Bob,
Volker
KaelLizak
(To:VolkerEckardt)
Hello Bob,
Did Volker's suggestion help?  If so, could you mark his post with the Correct Answer button?  If not, could you let us know how much further his suggestion got you?
By sharing your results with us, it lets us know if this issue has been resolved or not, and captures that knowledge so that others looking for the same or similar information can find out what worked for you.
Kael
Kind Regards,
Kael Lizak
