How to migrate from Integrity2009+MS SQL 2005 to Integrity10+ORACLE
和大坂
Hi all,
My name is Kazuhiko Osaka.
I'm an administrator of Integrity Server in my department.
I must migrate from Integrity2009 + MS SQL 2005 to Integrity10 + ORACLE.
Do you have any idea for such migration?
Any comment will be appreciated, thank you.
1 ACCEPTED SOLUTION
KaelLizak
(To:BineshKumar1)
Hello Ozaka-san, Binesh,
For more information, please see CS159657:  Where to get Integrity Database Utilities, and CS136276: Migrating Integrity Database to New Platform.  The short version is that you'll need to contact PTC Integrity Lifecycle Manager Support to get the proper utlity, and discuss this with them.
Kael
Kind Regards,
Kael Lizak
5 REPLIES 5
We have database utilities in Integrity  to do convert database backend. Please refer to Copy Database utility from http://support.ptc.com/WCMS/files/156959/en/dbutils_readme.htm
You have to check the same for your specif version
Binesh
Barry Wehmiller
KaelLizak
(To:BineshKumar1)
Kael
Kind Regards,
Kael Lizak
Thanks Kael for the update. We did an Oracle to SQL a few months ago on 10.4. I was not sure from where we received. I have one question for you, if you could assist - we have a fairly large database and would like to move to SQL Server (>1.4 TB), are you aware of any issues with this utility in handling large databases?
Binesh
Hello Binesh, Kael,
Thank you for your reply. I will check Integrity Database Utilities and come back soon!
Reagrds,
Kazuhiko
KaelLizak
(To:BineshKumar1)
Hello Binesh,
To my knowledge, the utility should work fine, even with a very large database.  It's actually the utility our Global Services Team uses to perform database migrations, not something that PTC Integrity Lifecycle Manager Support often uses.  We wouldn't give it to any customers if we had significant concerns about it, though.
Kael
Kind Regards,
Kael Lizak
