"MKS157416: MKS157416 No valid types for prefix "model.mathworks" and type property "model.mathworks.type" set to true." I get this error from matlab, when I try to synchronize my model with Integrtiy. Can someone help me?
Thank you!
Cemre
Hi Cemre,
What version of Integrity and Matlab integration, are you using?
Are these errors showing in the mathworks_xml.log file, or is anything else showing in there?
Was this previously working, or are you just trying to get this to work for the first time? Given the errors, I would suspect, it could be permissions related, or possibly you don't have Type Admin access.
You might want to open a Support case, to look into this.
