If there is an integer field on content level and same on document level as well and i want to summarize value of that field from all content to document level, is there any idea about this ?
kjain-2
E.g. ABC Requirement Document (Cost)
        ABC content (Cost)
If this document has 4 content inside this having cost value 10,20,30,40 for each so cost value in ABC Requirement Document should be 100.
Hi Kapil Jain
i would use a computed field with an aggregrate function. In this case you can't use the same field on for the segments and nodes. I would suggest to create a computed field "Aggregated Costs" for the document root with something like
IsEmpty(aggregate("Contains",ByDocument(true,true), sum("Cost")),0)
Please also check support document CS229357. There should be even more information that might be relevant to you.
Dominik
kjain-2
(To:D_Thierjung)
Thanks Dominik.
I got to know about this after putting question here and i also got the same as you suggested also.
Thanks a lot for your quick response.
Kapil
