Is it possible to run a sql command from a trigger?
phartwig
I have defined an executeCmdAs with the following command "im diag --diag=runsql --param=select login from mksdomainusers".  However, the following error is returned: "Runsql Diagnostic: SQL Statement execution failed: Invalid SQL type: sqlKind = UNINITIALIZED"
Thank you,
Paul Hartwig
Hi Paul,
why not just executing:   aa users
This returns the same result, and could also become a trigger element
Hope this helps
Volker
Volker,
   I need to determine which users are defined in the MKS domain and which users are coming from LDAP.  PTC provided me a way to get the information I need for this issue, but I still have another where I need to get the groups and their descriptions.
Thank you,
Paul Hartwig
Hello Paul,
What about:
a) integrity mksdomaingroups --fields=name,description
b) im groups --fields ....
Does that help?
