Is there a method for updating the Project level parameters via the command line interface?
rteifke
8-Gravel
DanR.
(To:rteifke)
im editproject --name=<value> --project=<project> --description=<value> --permittedAdministrators=u=user1;g=group1
DanR.
(To:rteifke)
What parameters would you be updating? The description, permitted Admins, Groups, project?
rteifke
8-Gravel
(To:DanR.)
They are Project Parameters. I would like to update/modify the Parameter Value from an HTML page or External PC Based Application(using the command line interface). We have a base set of parameters that are set at the requiremnts level, they then need some calculations to be performed on them to create test level parameters which need to set at the project level so that various test cases can have access to them.
DanR.
(To:rteifke)
