Sharing a Query
DanR.
Sharing a Query
I have a set of queries that are Admin queries and a shared to only two groups. One of them is NOT the everyone group. Why then when I login on as a user not in either of those groups am I still able to see these queries? On page 158 of the 2009 Integrity User Guide it says:
3 Click the Sharing tab. The Sharing panel displays.
 Click Choose Principals and use the data filter to select the principals (users and groups) that you want to share your query with.
NOTE  Only the groups you add to the Shared With list can see your query. 
1 ACCEPTED SOLUTION
DanR.
(To:DanR.)
I discovered the issue. Under "Workflows and Documents" > "Permissions" > "Global" I had a group with the "CreateSharedAdmin" set to allowed. Once I changed it to deny the shared queries in question were no longer visible.
mrump
(To:DanR.)
... but the other one is.
So basically you share with the group "everyone" and explains your systems behavior pretty well.
DanR.
(To:mrump)
But I am NOT sharing with the everyone group because I do not want everyone to see these queries.
DanR.
(To:DanR.)
KaelLizak
(To:DanR.)
Hi Dan,
I'm glad that worked out. I think you might want to just unset that ACL, though: If you have a user who is a member of that group and a member of a group which does have CreateSharedAdmin allowed, they won't be able to create Admin objects unless they're granted CreateSharedAdmin at the user level, because in a conflict at the same level between allowed and denied, denied wins.
-Kael
Kind Regards,
Kael Lizak
