Using Jenkins to execute an IM command
phartwig
     I am trying to setup a Jenkins build that will execute an Integrity IM command.  I have installed the Jenkins server on a Windows workstation that also has the Integrity thick client installed.  If I add the IM command directly to the Jenkins project, the error "Attempt to launch Integrity Client timed out" is returned.  I then created a batch file where I added the IM command and the result is the same.  PTC Support then suggested that I run the IM command from it's own instance.  When I execute the build this way, the job returns that it was successful.  However, the command was not executed.
Does anyone have any other suggestions to try?
Thank you,
Paul Hartwig
1 ACCEPTED SOLUTION
phartwig
(To:phartwig)
I have determined that the user that the service runs as "Local System" is not able to launch the Integrity client.  I temporarily changed the server to a network user and the build will execute successfully.
Is it possible to give the "Local System" access to launch the Integrity Client?  Due to security settings (password expiration), I would like to avoid using a network user for the service.
I would be interested what is meant by "from it's own instance" from the jenkins perspective.
Is it "Execute Shell" instead of "Executing Windows Batch" ?
Although I only have experience with the si command I can imagine than
at least for your first approach it might be helpful if you export your environment variables to a text file
and compare it  to environment variables you saved in a command window
where your im command is working.
jenkins.bat (called by jenkins)
set > c:\tmp\jenkins_ENV.txt
Console
c:\tmp>set > console_ENV.txt
c:\tmp>set > your_difftool jenkins_ENV.txt console_ENV.txt
Just an Idea:
HTH Jürgen
phartwig
(To:phartwig)
KaelLizak
(To:phartwig)
Hello Paul Hartwig‌,
I believe that's a restriction of Windows on the Local System user.  This article on StackOverflow seems to confirm that, and provides ways around it.
Cheers!
-Kael
Kind Regards,
Kael Lizak
