What return values are expected of a Diff/Merge Third Party Tool?
fpeschka
We are using MKS Integrity 2007 and I'm trying to implement Beyond Compare 4 as a Diff/Merge tool.
Calling the program works fine with the tutorial over here: Beyond Compare Technical Support
The only problem is that, after merging, MKS tells me that "The merge status from the third party tool is unknown".
The return values of Beyond Compare seem rather obvious and sensible - 0 for successful merge.
What does MKS expect as a return value here, so the merge is automatically considered successful? Is there a list of return values and what MKS interprets them as?
1 ACCEPTED SOLUTION
KaelLizak
(To:fpeschka)
I haven't tried it out (I don't have BC4), but I suspect it won't work, based mainly on some internet searches.  It wouldn't be that difficult to try, though.
Source Integrity diff return codes are here under Diagnostics.  BC4 return codes are here under Return codes.
I'm curious to learn what you find.
Kind Regards,
Kael Lizak
5 REPLIES 5
KaelLizak
(To:fpeschka)
Hello Florian Peschka‌,
Currently, Source Integrity doesn't support Beyond Compare v4.  Please contact PTC Integrity Lifecycle Management Support to register your organization with enhancement RFC 997067/CS186778‌.
Kael
Kind Regards,
Kael Lizak
Thanks for the reply. Unfortunately I am not in a position to decide such things, but I will pass it along.
In the meantime... would it not work to create a batch file that maps Beyond Compare return codes to the ones that Source Integrity expects?
If I knew the codes I need to return, this seems like a minor problem to work out, but I cannot find the list of what return codes Source Integrity expects from the third party tool.
KaelLizak
(To:fpeschka)
Kind Regards,
Kael Lizak
KaelLizak
(To:KaelLizak)
Did those values help you at all?
Kael
Kind Regards,
Kael Lizak
Yes, they helped - I am now trying to create an in-between Tool that will translate between the two. Unfortunately this is not as easy as I thought.
I will report if I have any considerable success.
