com.mks.api.response.APIConnectionException: Remote host closed connection during handshake
ptc-6124669
I keep getting this error when running my code:
import com.mks.api.CmdRunner;
import com.mks.api.Command;
import com.mks.api.IntegrationPoint;
import com.mks.api.IntegrationPointFactory;
import com.mks.api.Option;
import com.mks.api.Session;
import com.mks.api.response.APIException;
import com.mks.api.response.Response;
public class MksMain {
@SuppressWarnings("deprecation")
public static void main(String[] args) {
String host = "";
int port = 7001;
boolean secure = true;
String user = "";
String password = "";
try {
IntegrationPoint ipf = IntegrationPointFactory.getInstance().createIntegrationPoint(host, port, secure, 4, 11);
Session session = ipf.createSession(user, password);
CmdRunner cmd = session.createCmdRunner();
cmd.setDefaultHostname(host);
cmd.setDefaultPort(port);
cmd.setDefaultHostname(user);
cmd.setDefaultPassword(password);
Command connect = new Command(Command.SI, "connect");
connect.addOption(new Option("",""));
Command checkout = new Command(Command.SI, "co");
checkout.addOption(new Option("", ""));
Command disconnect = new Command(Command.SI, "disconnect");
cmd.execute(checkout);
Response response = cmd.execute(checkout);
String resID = response.getResult().getMessage();
System.out.println("Established connection " + resID);
catch (APIException e){
System.out.println("oops");
e.printStackTrace();
Happens after line cmd.execute(checkout);
Any ideas?
Thanks in advance!
KaelLizak
(To:ptc-6124669)
Hello Andrei,
In this sort of situation, I would normally recommend contacting PTC Integrity Support to examine this issue, but I see that your account is not associated with a maintenance contract.
Could you supply some logging from the <ServerHome>/log/server.log file?
Are you using additional jar files? If so, are you sure you have the correct classpath to access those jar files?
Kael
Kind Regards,
Kael Lizak
