javascript createContent command
mbohanon
I am attempting to create content using a javascript trigger command delta.createContent. When doing this, I get an error
MKS124701: Field "Contains" may not be set. It is a solution managed field.
I am working with Integrity 10.3 with ALM solution.
Does this command work? Is this error due to the ALM solution? Is there a way to make it work? Is there a setting that will make it work?
Mark
1 ACCEPTED SOLUTION
Hi Mark, this is a known problem but is being worked on for one of our upcoming releases. Assuming all goes well and no last minute problems arise, it should be fixed with the Integrity 10.4 release in June. Until that time, the CreateContent() method will unfortunately not work in triggers.
Joe Bartlett
Joe Bartlett
