resynching change packages
hmagnanao
I'm trying to resync change packages for merging using the si.exe resynccp command. Is there an option to this command to skip certain files in the change package when merging ?
Unfortunately, there is no way to specify files to use or skip in merge. The merge options in the resynccp command are limited to the following:
--[no|confirm]merge Confirm whether or not to perform merges
--[no|confirm]mergeOnBranch If target revision is on a branch, perform a merge.
--mergeType=[confirm|cancel|automatic|manual] Try to automatically perform the merge or launch the conflict resolution tool
--notify=[never|onCompletion|onError] Display report when the operation is complete
--onMergeConflict=[confirm|cancel|mark|launchtool|highlight|error] What to do when conflicts occurred during the merge
