why xml is treated as a binary in Integrity 10.5
pyamamoto
hello, I have xml files that want to upload to our PTC Integrity Source server 10.5
I noticed when I choose Data Type to "Auto" (default), then the file is sucessfully loaded, but as binary, and I miss the PTC integrity keywords expanded there.
when I try to use "Text",  then  I got the error message as attached
I don't understand why, because file is valid xml , and can be opened by any text editor and browser.
see a sample small XML file attached.
just in case, this is version we are using here
Thanks for any help in advance,
Pablo
The reason this XML file is identified as Binary is because there is a single line of text longer than 16k characters.
See Article 84232 for details.
LLawton
(To:pyamamoto)
I use v10.4 and have no problems with xml files.
I had a quick look at the file you enclosed and it does seem to contain binary data.
Do you have a smaller, simpler, pure text file you could test with?
If this file is generated by another application, you may want to add a true text-xml file first with the same name to force Integrity to register it as text, then check-in the real file and see what happens.
Windchill RVS Users
Please take our
Windchill RV&S Authoring with Formula Editor Survey
