why xml is treated as a binary in Integrity 10.5
pyamamoto
hello, I have xml files that want to upload to our PTC Integrity Source server 10.5
I noticed when I choose Data Type to "Auto" (default), then the file is sucessfully loaded, but as binary, and I miss the PTC integrity keywords expanded there.
when I try to use "Text",  then  I got the error message as attached
I don't understand why, because file is valid xml , and can be opened by any text editor and browser.
see a sample small XML file attached.
just in case, this is version we are using here
Thanks for any help in advance,
Pablo
1 ACCEPTED SOLUTION
The reason this XML file is identified as Binary is because there is a single line of text longer than 16k characters.
See Article 84232 for details.
LLawton
(To:pyamamoto)
I use v10.4 and have no problems with xml files.
I had a quick look at the file you enclosed and it does seem to contain binary data.
Do you have a smaller, simpler, pure text file you could test with?
If this file is generated by another application, you may want to add a true text-xml file first with the same name to force Integrity to register it as text, then check-in the real file and see what happens.
