I've been somewhat frustrated that after upgrading to Windchill Quality Solutions, after using RELEX for many years, I've lost one of my favourite features, 3D graph generation.
The graph below was generated in RELEX 2011, it looks fantastic in a report. Now after the upgrade at great expense the capability to generate this graph is no longer available. ![]()
PTC please can you re-introduce!!
You may wish to pose this as a product suggestion for voting.
I don't know how to do that.
At this moment I'm exporting my data from WQS, install RELEX 2011, import the data, then print the graph. Oh the pain.
Go to the product idea tab and then just below it to the right will be actions. Click on create a product idea and then it is similar to how you started the discussion.
Once your done, you go back into your idea and for yes on it.
Thanks, Dale
BTW: Welcome to the forum.
You need to edit your reply and click your link and the click the link button to unlink it (The A with the underscore and links of chain). Then just click somewhere else in your email. For some reason it screws up and adds a double portion of part of the link and therefore it doesn't work
One of the suggestioned to fix it is here:
http://communities.ptc.com/thread/38223?tstart=0
Thanks, Dale
Looks like it does. ![]()
Hello and Welcome,
Should this discussion and the corresponding Product Idea be in the PTC Windchill Community and filed under the Quality Management category?
Let me know and I'll make the move.
-Dan
I don't know.
Any thoughts on a solution?
