I'm in the process of moving away from using Promotion Notices toChange Notices for our nonproduction changes.
In our Promotion Process we use the Lock transition to move an object to Under Review. If thePromotion is cancelled or rejected, the objects go back to theoriginating state of the object. Also if we Rework the Promotion, it goes back to the originating State which will allow the users to edit the objects before going through the review cycle again.
I'm trying to figure outhow to do the same thing within the ECN process.
I have a method that I created to set the changeables state to a given state. So it can be Under Review or say Prototype.
But if they need to Rework the change, I want the objects to go back to their original states. To me that seems like I need to create some variable and store a list of the objects and their starting state... I'm not sure I can use the new Refine transition, since it has not been set in my current lifecycle template.
Just wondering what approach I should take to solving this.
Steve D.
Place a "Set State" Robot in your workflow loopback path.
Russ
