A possible fix for the 9.1 text truncation
sdrzewiczewski
After Antonio's presentation from PTC/User this year, I was able to apply some of his slides to address an issue that our users have been complaining about since we moved from 9.0 to 9.1. That is around the truncation of the text and having to hover over a column to see a Comment, or a long Name field.
The solution that we came up with and is still being tested and is not guarnteed, is the following
create a .css file and store some place in the codebase folder. (in our case codebase\netmarkets\jsp\iRobot\<filename.css>
in that file i put the following lines
.jstdotspan { display:none; width:0;white-space:normal;height:auto;}
.cell_long_text_width{white-space:normal;height:auto;}
.cell_long_text{white-space:normal;height:auto;}
.tablecolumnheaderfont{white-space:normal;height:auto;}
.pplabel{white-space:normal;height:auto;}
.jsttextcell{white-space:normal;overflow: visible; height:auto;}
.jsttdt {white-space:normal;overflow:visible;height:auto;}
.jsttdt div {overflow:visible;}
.jstdtbody tr{height:auto;}
Then in codebase\netmarkets\jsp\util\begin.jspf
add the following line of code
<link rel="stylesheet" href="&lt;folder" location=" of=" css=" file=">/<filename.css>" type="text/css"></link>
right before the </head>
Save the file and restart Windchill.
I've tested this with Firefox, Chrome and IE. IE 8 works well, IE 6 doesn't like to change the height after you resize a column width.
If you do use this and find any errors or additional modifications, please share back with the community.
minor correction... instead of editing begin.jspf, you can just put the line of code in
begin_custom.jspf instead.
adding it to the begin_custom.jspf didn't work, i think because the <filename>.css wasn't the last .css file read in.
