What is the different between a DynamicRole and RoleGroups in Windchill 11.0? Where can I find a documentation about the different group types?
Both are used in the Context Template xml (see snipped below). The ACLs are created with the UI.
<AccessControlRule>
<domainName>/Default</domainName>
<externalTypeId>WCTYPE|wt.doc.WTDocument|priv.Domain.MyDocument</externalTypeId>
<lifecycleState>RELEASED</lifecycleState>
<WTPrincipalReference isInternal="true">
<groupName>DOCUMENT_MANAGEMENT</groupName>
<groupType>DynamicRole</groupType>
</WTPrincipalReference>
<grantPermissionSet><AccessPermissionSet>
<permissionField name="READ"></permissionField>
<permissionField name="REVISE"></permissionField>
<permissionField name="CHANGE_PERMISSIONS"></permissionField>
<permissionField name="DOWNLOAD"></permissionField>
<permissionField name="SET_STATE"></permissionField>
</AccessPermissionSet></grantPermissionSet>
</AccessControlRule>
<AccessControlRule>
<groupType>roleGroups</groupType>
<permissionField name="CREATE"></permissionField>
Thank you,
Tom
Please see this article.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS161997
