API call through table builder
WM_9965332
Hi all,
I have a wizard jsp page where I have defined an MVC table and a html button. The intent is once the user clicks the button, system will reload the table using PTC.jca.table.Utils.reload. My table builder contains code which makes an API request to get some validation response which will be displayed on the table. A wizard button on UI will be enabled/disabled based on table row output (safe to assume table will always have one entry).
I have noticed that once I reload the table and try to get the updated row(s) I don't get any values since the table is still reloading by the time the program calls "PTC.jca.table.Utils.getTableRows". To mitigate this I set a timeout so it waits for table to finish reload, but I cannot determine on average how long it would take to make the call.
Is it possible to have some async/await in this scenario? Or perhaps use a different approach?
I went with the above approach since I want the user to know an operation is happening (system making API call) and be able to see response without using window.alert
Hi WM_9965332,
Thank you for your question.
I’d like to recommend to bring more context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
