API for Windchill User Login Event
BenPerry
When a user logs in, there is a record added to the database in the AUDITRECORD table.  I assume some java code is executed when a user logs in, to put that record in the database.
I was thinking about leveraging this API to do some additional things, such as check the user's preferred file server (their vaulting preference).  I could add additional code to this java class do what I desire.  But first I need to determine what API is triggered during the login.
Anyway have ideas of which API(s) are triggered during user login?
akhan
(To:BenPerry)
Whenever a user logs in I think SessionUserAuditEvent.LOGIN event is fired. See if you can do what you want in this event listener.
BenPerry
(To:akhan)
Abdul,
Thanks.  I added a System.out.println() statement to SessionUserAuditEvent(), but I didn't see anything in the MS or BMS logs.  Should I expect to see something there?  Or somewhere else?
  public SessionUserAuditEvent(String paramString, WTPrincipalReference paramWTPrincipalReference, long paramLong, int paramInt)
    super(paramString);
    this.event = paramString;
    this.user = paramWTPrincipalReference;
    this.time = paramLong;
    this.concurrency = paramInt;
    System.out.println("\n\n\n\n\nMyStatement\n\n\n\n\n");
BenPerry
(To:akhan)
Abdul,
Nevermind.  I'm an idiot.
  1. I might not have saved the .java file before compiling.
  2. I certainly did not restart Windchill.  Restarting is necessary so it will pick up a new .class file instead of using the cached one.
After the Windchill restart, I refreshed a page, and "My Statement" was printed to the foreground MS log.  This is a start.  I might have more questions later.
BenPerry
(To:akhan)
Abdul,
A few observations after running it for a little while today...
  1. It does indeed "re-login" a few times through the day.  The Windchill server kept running, and the code was triggered 3 times.  But the user never restarted the browser.  He was in the same session.  (10:40 AM, 11:16 AM, 1:17 PM)
  2. Somehow, it is being triggered even without the user logging into Windchill.  For example, I restarted the server, but never refreshed my browser page or anything.  I was busy doing other things.  But during that time, my name was printed to the MS log.
FYI...Here are my current modifications to wt.session.SessionUserAuditEvent:
    super(paramString);
    // START ADDITION
    System.out.println("\n\n\n");
    System.out.println("Login event for " + user.getIdentity());
    // END ADDITION
Hi Ben,
Was the user inactive. Looks like there was no activity and the session was timeout after a certain interval defined by wt.session.sessionUsers.timeout property, you can add log-out event to check if that was the case.
Bhushan
