Access deny: How to run background task periodically
HelesicPetr
22-Sapphire I
I don't have access to the Discussion "How to run background task periodically ",
https://community.ptc.com/message/472772
found in https://community.ptc.com/t5/Windchill/Is-there-anyway-to-schdule/m-p/184990#M56259 post
Why i dnot have access to the original topic?
I would like to get an access.?
Thank you so much for an answer.
Best Regards
Petr H.
Interesting answer was published in the original discusion:
If you wan't to use a time, you need to create a Windchill context :
import wt.method.MethodContext
import wt.method.RemoteMethodServer
import wt.session.SessionContext
import wt.session.SessionHelper
new MethodContext(null, null)
SessionContext.newContext()
SessionHelper.manager.setPrincipal("wcadmin")
RemoteMethodServer rms = RemoteMethodServer.getDefault()
rms.setUserName("wcadmin")
rms.setPassword("wcadmin")
But as Bjorg said, it's not the best way. In fact, if you have several MS & a BGMS, the thread would run everywhere, and it would probably raise stranges issues.
I had to do something similar, and I used wt.queue.ScheduleQueue and its associated entry wt.queue.ScheduleQueueEntry
ScheduleQueueEntries have a "processAt" parameter.
The algorithm is :
    In a service, check that the custom schedule queue exists
    if no create it
    Is there an entry in the queue ?
    if yes, do nothing
    if no, add a new one, scheduled to execute at a specific date
And iat the end of the code launched by the ScheduleQueueEntry, you add a new entry in the queue. So there is always a pending job.
Some code :
The starting point is to call addQueueEntry(); in the performStartupProcess method.
Everyhting is done from this method.
Of course you need to define some constants, like HAGER_QUEUE_NAME
private static ScheduleQueue initialiseQueue(String qname)
   throws WTException {
  ScheduleQueue q = (ScheduleQueue) QueueHelper.manager.getQueue(qname, wt.queue.ScheduleQueue.class);
   if (q == null) {
  q = createScheduleQueue(qname);
   //QueueHelper.manager.setInterval(q, interval);
  // q = (ScheduleQueue)PersistenceHelper.manager.save(q); Voila qui ne m'a plus l'air n�cessaire.....
   if (logger.isDebugEnabled()) {
  logger.debug("initialiseQueue() - " + CLASSNAME + ".initialiseQueue() Creating Queue " + qname); //$NON-NLS-1$ //$NON-NLS-2$
  logger.debug("initialiseQueue() - " + CLASSNAME + ".initialiseQueue() Starting Queue " + qname); //$NON-NLS-1$ //$NON-NLS-2$
  QueueHelper.manager.startQueue(q);
   return q;
//##begin newStandardHagerService%newStandardHagerServicef.doc preserve=no
private static ScheduleQueue createScheduleQueue(String qname)
  ScheduleQueue schedulequeue = null;
   try {
  schedulequeue = QueueHelper.manager.createScheduleQueue(qname);
  } catch (ObjectIsStaleException objectisstaleexception) {
  schedulequeue = (ScheduleQueue) QueueHelper.manager.getQueue(qname, wt.queue.ScheduleQueue.class);
  } catch (UniquenessException uniquenessexception) {
   return schedulequeue;
//##begin getAllSigleService%3BF8E35000FAg.doc preserve=no
public static void addQueueEntry() {
  ScheduleQueue queue = null;
// Check existing entries
   try {
  QuerySpec qs = new QuerySpec(wt.queue.ScheduleQueueEntry.class);
  ClassAttribute theClassAttribute = new ClassAttribute(wt.queue.ScheduleQueueEntry.class, "targetClass");
  RelationalExpression theExpression = ConstantExpression.newExpression("ext.hager.services.StandardHagerService", theClassAttribute.getColumnDescriptor().getJavaType());
  SearchCondition theCondition = new SearchCondition(theClassAttribute, SearchCondition.EQUAL, theExpression);
  qs.appendWhere(theCondition);
  qs.appendAnd();
  theClassAttribute = new ClassAttribute(wt.queue.ScheduleQueueEntry.class, "statusInfo.code");
  theExpression = ConstantExpression.newExpression("READY", theClassAttribute.getColumnDescriptor().getJavaType());
  QueryResult qr = PersistenceServerHelper.manager.query(qs);
   if (qr.size() > 0) {
  // Found something
  logger.debug("addQueueEntry() - " + CLASSNAME + ".addQueueEntry() No need to add an entry. "); //$NON-NLS-1$ //$NON-NLS-2$
   return;
  } catch (WTException wte) {
  logger.debug("addQueueEntry() - " + CLASSNAME + ".addQueueEntry() Exception caught " + wte.toString()); //$NON-NLS-1$ //$NON-NLS-2$
  logger.error("addQueueEntry()", wte); //$NON-NLS-1$
   return;
   try {
  queue = initialiseQueue(HAGER_QUEUE_NAME);
  GregorianCalendar cDate = new GregorianCalendar();
  cDate.add(Calendar.DAY_OF_YEAR, NB_JOURS_SCHED_QUEUE);
  cDate.set(Calendar.HOUR, HEURE_TACHE_ARCHIVAGE);
  cDate.set(Calendar.MINUTE, 0);
  cDate.set(Calendar.SECOND, 0);
  Timestamp processAt = new Timestamp(cDate.getTime().getTime());
   //processAt = new Timestamp((new java.util.Date()).getTime()+10000);
   WTPrincipal user = SessionContext.getEffectivePrincipal();
  WTPrincipal admin = SessionHelper.manager.getAdministrator();
  WTPrincipal admin2 = SessionContext.setEffectivePrincipal(admin);
   queue.addEntry(
  admin,
   "archiveDocuments",
  CLASSNAME,
   new Class[]{},
   new Object[]{},
  processAt);
  logger
  .debug("addQueueEntry() - " + CLASSNAME + ".addQueueEntry() Prochaine recherche des documents obol�tes �  " + cDate.getTime()); //$NON-NLS-1$ //$NON-NLS-2$
  SessionContext.setEffectivePrincipal(user);
  logger
   return;
//-------------------------------------- code executed by the queue :
public static void archiveDocuments() throws WTException {
  // all the hthings you need goes here...
// And here we go again.
  addQueueEntry();
Simona
(To:HelesicPetr)
Hi @HelesicPetr ,
I just did an update to that specific post and it should be visible for everyone now.
Simona
Simona
(To:HelesicPetr)
Hi @HelesicPetr ,
Simona
HelesicPetr
22-Sapphire I
(To:Simona)
Hello Simona,
Thank you so much.
BestRegards
PetrH
