Hello
I'm writing advanced API Query to fetch the all parts latest version and iteration but I'm unable to execute the query. Here my code:
import wt.fc.QueryResult;
import wt.inf.library.WTLibrary;
import wt.part.WTPart;
import wt.part.WTPartMaster;
import wt.query.ClassAttribute;
import wt.query.OrderBy;
import wt.query.QueryException;
import wt.query.QuerySpec;
import wt.query.SQLFunction;
import wt.query.SearchCondition;
import wt.query.SubSelectExpression;
* @author mgangappa
public class Extractor {
public static void main(String[] args) {
Extractor ex = new Extractor();
ex.getAllPartsLatestVersionAndIteration();
public void getAllPartsLatestVersionAndIteration() {
try {
final QuerySpec qs = new QuerySpec();
qs.setAdvancedQueryEnabled(true);
final int lib = qs.addClassList(WTLibrary.class, false);
final int masterIndex = qs.addClassList(WTPartMaster.class, false);
final int partIndex = qs.addClassList(WTPart.class, true);
final QuerySpec subSelect = new QuerySpec();
final int partSubInt = subSelect.appendClassList(WTPart.class, false);
final SQLFunction max = SQLFunction.newSQLFunction(SQLFunction.MAXIMUM, new ClassAttribute(WTPart.class, "iterationInfo.branchId"));
subSelect.appendSelect(new ClassAttribute(WTPart.class, "masterReference.key.id"), new int[]{partSubInt}, true);
subSelect.appendSelect(max, new int[]{partSubInt}, true);
subSelect.setAdvancedQueryEnabled(true);
subSelect.appendGroupBy(new ClassAttribute(WTPart.class, "masterReference.key.id"), new int[]{partSubInt}, true);
qs.appendWhere(new SearchCondition(WTLibrary.class, WTLibrary.NAME, SearchCondition.NOT_LIKE, "%test%"), new int[]{lib});
qs.appendAnd();
qs.appendWhere(new SearchCondition(WTPartMaster.class, "containerReference.key.id", WTLibrary.class, "thePersistInfo.theObjectIdentifier.id"), new int[]{masterIndex, lib});
qs.appendAnd();
qs.appendWhere(new SearchCondition(WTPart.class, "masterReference.key.id", WTPartMaster.class, "thePersistInfo.theObjectIdentifier.id"), new int[]{partIndex, masterIndex});
qs.appendAnd();
qs.appendWhere(new SearchCondition(WTPart.class, WTPart.LATEST_ITERATION, SearchCondition.EQUAL, true), new int[]{partIndex});
qs.appendAnd();
final SubSelectExpression inList = new SubSelectExpression(subSelect);
inList.setAccessControlRequired(false);
qs.appendWhere(new SearchCondition(new ClassAttribute(WTPart.class, "iterationInfo.branchId"), SearchCondition.IN, inList), new int[]{partIndex});
qs.appendOrderBy(new OrderBy(new ClassAttribute(WTPartMaster.class, WTPartMaster.NUMBER), true), new int[] {masterIndex});
QueryResult qr = ExecuteQueryInServerContext.executeAdvanceQueryInServer(qs, "executeQuery");
} catch (QueryException ex) {
ex.printStackTrace();
I'm executing it in the RemoteMethodServer.invoke (see below code):
import java.lang.reflect.InvocationTargetException;
import java.rmi.RemoteException;
import wt.fc.PersistenceHelper;
import wt.fc.PersistenceServerHelper;
import wt.method.RemoteAccess;
import wt.method.RemoteMethodServer;
import wt.pds.StatementSpec;
import wt.util.WTException;
* @author mgangappa
public class ExecuteQueryInServerContext implements RemoteAccess {
public static QueryResult executeAdvanceQueryInServer(QuerySpec query, String method) {
Class[] pClasses = new Class[1];
pClasses[0] = QuerySpec.class;
Object[] pObjects = new Object[1];
if (query == null) {
return null;
} else {
pObjects[0] = query;
try {
return (QueryResult) RemoteMethodServer.getDefault().invoke(method, ExecuteQueryInServerContext.class.getName(), null, pClasses, pObjects);
} catch (RemoteException ex) {
} catch (InvocationTargetException ex) {
return null;
public static QueryResult executeQuery(QuerySpec qs) throws WTException {
System.out.println("executeQuery => PersistenceServerHelper ");
QueryResult result = PersistenceServerHelper.manager.query(qs);
return result;
public static QueryResult executeQueryManager(QuerySpec qs) throws WTException {
QueryResult result = PersistenceHelper.manager.find((StatementSpec) qs);
return result;
But I'm keep getting the below error:
nServerContext, executeQuery, , 0, 0, 0.0, 0, 0.0, 0.01, 0.007444714
(wt.pds.pdsResource/23) wt.pds.AdvancedQueryAccessException:
Access is not permitted to advanced query capabilities.
at wt.pds.SQLDatabasePds.query(SQLDatabasePds.java:616)
at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1108)
at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1017)
at wt.fc.StandardPersistenceManager._query(StandardPersistenceManager.java:1878)
at wt.fc.StandardPersistenceManager.query(StandardPersistenceManager.java:1417)
at wt.fc.StandardPersistenceManager.query(StandardPersistenceManager.java:1301)
at com.google.extractor.ExecuteQueryInServerContext.executeQuery(ExecuteQueryInServerContext.java:50)
What I'm doing wrong? Do I need to set or change config?
Manjunath Reddy
Hi Lori,
Yes, this is resolved with the attached modified Java files. Manjunath Reddy confirms as this is resolved.
Shirish
Hi Manjunath,
I noticed that you opened a case with Tech Support to investigate this issue (C12944368). Did using the QuerySpec.setAdvancedQueryEnabled(true) method in your code resolve this issue?
Hi Lori,
Shirish
You should mark this post as answered.
