Add attributes to manifest.xml in PE payload
JeffStevenson
I need to find a way to include the state of a Dynamic Document in the PE process for SIM. The manifest.xml file that is included in the payload sent to PE contains a few attributes by default (i.e. Revision, Iteration, timestamp, CADnumber) and all global attributes. Is there a way to add other attributes to the manifest file? Or more to the point, what is the criteria for the attributes that are added?
Thanks!
I answered my own question. The attributes can be added (or removed) by modifying manifest_attset.xml in codebase\com\ptc\arbortext\windchill\siscore\attset\xml. There are configurations files depending on what XML you are affecting in the payload. Restart MS after making your changes.
More info can be found in the SIM/Service Parts config guide.
