Adding IBAs in Windchill for ModelCHECK
BuddyHudson
To all ModelCHECK users,
I am trying to implement ModelCHECK and follow the instructions of adding the instance -based attributes into Windchill....
Although the Gatekeeper documentation says to add these, it does not define specifically where. I am ASSuming that it means under Site>Utilities>Type and Attribute Manager, select CAD Document, then add the following MODEL_CHECK (string), MC_ERRORS (integer), and so forth. It states in the documentation that these need to be "mapped" to the parameters of parts, assemblies, drawings. Ok i think I get what this means....turn on the param creation of these parameters in modelcheck config and they will match up to the IBAs once you try to check them in??? Is that not an easier way to explain this cuz it confuses the hell out of me how they over engineer the technical language in these documents sometimes...any help would be appreciated to clarify.
Buddy
0 REPLIES 0
