Adding a new attribute in the ESI Response XML file
Panther_0312
Consider, a part has new attribute added to it. Now, at the time of publishing, the user wants this new attribute to be included in the Response XML file that will be published. How to add this new attribute in the ESI Response XML file?
You need to modify the template if you want an attribute to be written out:
https://www.ptc.com/en/support/article/CS351131?source=search
This is not done dynamically but setup ahead of time.
Hi @Panther_0312
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
