Setting the default value for the OOTB WTPart attributes via OIR
ArjenBlok
Can you tell me how I can set the default value for the OOTB WTPart attributes (End Item, Assembly Mode, Source, etc.) via OIR? We would like to set different default values across context.
Use case:
We have a library for purchased component. These parts should have a default value of Buy for Source. We manage our own products in product containers where the default value for Source should be Make.
1. Add the following Object Initialization Rule to your type (wt.part.WTPart)
<!-- set the Boolean IBA -->
    <AttrValue id="endItem" algorithm="wt.rule.algorithm.BooleanConstant">
        <Arg>true</Arg>
    </AttrValue>
<!-- set the String IBA -->
  <AttrValue id="source" algorithm="wt.rule.algorithm.StringConstant">
  <Arg>buy</Arg>
  </AttrValue>
  <AttrValue id="partType" algorithm="wt.rule.algorithm.StringConstant">
  <Arg>inseparable</Arg>
  </AttrValue>
<!-- specify AttrConstraint tag -->
  <AttrConstraint id="endItem" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
  <Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
  </AttrConstraint>
  <AttrConstraint id="source" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
  </AttrConstraint>
  <AttrConstraint id="partType" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
  </AttrConstraint>
2. Edit the following  %WT_HOME%\codebase\com\ptc\core\rule\server\delegate\init\RuleConfigurableTypeAttribute.properties.xconf:
   <Property name="wt.part.WTPart" default="number,name,lifeCycle,lifeCycle.id,teamTemplate,teamTemplate.id,folder.id,organization.id,endItem,source,partType"/>
3. Run "xconfmanager -pF" in Windchill Shell and restart Windchill
12 REPLIES 12
You need to go to Type and Attribute manager, edit the type, then select the attribute. See panel on right
Setting a default value for the End Item does not work.
another related post with other options - Setting the default values for the OOTB WTPart attributes
Darren, do you have an instruction how to realize the solution described in the mentioned related post? I don't see how I can define different default values for product containers and libraries.
I didn't know that its not possible to set the default value on this...Interesting.... I wonder if this applies to all modeled attributes or just this one? I have not personally tried to achieve this any other way, sorry I can't provide instructions.
This way you define only one default value for all contexts. I want to differentiate across containers and libraries.
OliverDroop
(To:ArjenBlok)
You would need to load dedicated OIRs in every product container to differentiate the default value. This is somehow manageable.
As far as I remember you need to specify modeled attributes in a WT. Property which should be altered by the OIR. We have done this for the partstructureoverride attribute in the past.
        <Arg>true</Arg>
    </AttrValue>
  <Arg>buy</Arg>
  </AttrValue>
  </AttrValue>
  </AttrConstraint>
  </AttrConstraint>
  </AttrConstraint>
Thanks for the proposes solution! We will try this at short notice. I will inform you about our findings.
Sergey, thanks for this perfect solution! Problem solved!
mwaite
(To:SergeyEfimov)
I followed the steps, but it doesn't work.  It seems like the default set in the enumcustomize application overrides the values I set in the OIR.
OliverDroop
(To:mwaite)
as far as I remember you need to remove the default in type manager.
For Master attributes the default need to be removed on WTPartMaster as well
