Greetings Community,
We are having to make a mass change where we need to remove a Part (WTPart) from many assemblies. Is there a way to collect all the "Where Used" assemblies into the affected items table without having to find them individually.
Thanks in advance,
Cam
BTW... we are using Windchill 10.1 m050
yes.
Found the answer... I was not looking in the correct place
Use the "Collect object where the selected object is used" in the collector.
seems like a silly question now.
