We would like to configure Windchill server with 7 File Servers to achieve the following requirement.
There is a Product container X and user A is from US and user B is from India.Both are members of this Product Container.
Both members are required to design two separate product lines using Creo.
If user A checks in Creo data it should be deposited in US FCS Master vault and if user B checks in data then it should be deposited in India FCS master vault.
Is there any good bractice to configure Replica Vaulting Rules according to this requirement? How can we make sure that data is not stored centrally?
Hello!
Did you read this document http://support.ptc.com/WCMS/files/94691/en/WindchillVaultReplication.pdf ?
Thanks for that document.
I know them. In my opinion this document describes some solutions only theoretically.
Also the legislative has been changed during the time in USA.
Change some data to another country then US is more strict and can not be done automatically
if the master server is not in US.
In the end the document is good start for every body who plans the replication file server.
