AfterEDRloader - use the CAd Doc Number instead of name to generate additional file name
jbailey
Is there a way to use AfterEDRLoader to pull the number of the cad doc for the additional file instead of the name field?
8 REPLIES 8
TomU
(To:jbailey)
jbailey
(To:TomU)
So would I use epmdoc_number?
Vincent-Kulak
(To:jbailey)
Yes
jbailey
(To:jbailey)
So in that article it showed the parameter was epmdoc_number... when it is in fact epmdoc_Number .... gotta love java.  The entire problem was because of a capital letter that I couldn't find the proper syntax 🙂
G_U
11-Garnet
11-Garnet
(To:jbailey)
Hi Guys,
I also tried the same article - CS252900 but not working for me still pdf file name is coming like filename_drw.
Do I have to consider any other stuff also?
jbailey
(To:G_U)
Have you modified your publishing rules to specify the number?
Something like this
G_U
11-Garnet
11-Garnet
(To:jbailey)
HI,
As of now, I am generating pdf from the recipe, not from the publishing rule, do I have to switch to the publishing rule.
if yes I hope it should not impact on pdf quality right?
Gourav Upadhyay
jbailey
(To:G_U)
So its a PDF representation, not HPGL?
As far as I know, the AfterEDRloader only controls how the "Additional Files" are identified.  The publishing rules are going to say what "extra" files are being published - including PDF's
When you right click on the representation in the annotation view, are there any "Additional Files" ?
