Is there a way to use AfterEDRLoader to pull the number of the cad doc for the additional file instead of the name field?
Yes
So in that article it showed the parameter was epmdoc_number... when it is in fact epmdoc_Number .... gotta love java. The entire problem was because of a capital letter that I couldn't find the proper syntax 🙂
Hi Guys,
I also tried the same article - CS252900 but not working for me still pdf file name is coming like filename_drw.
Do I have to consider any other stuff also?
Have you modified your publishing rules to specify the number?
Something like this
HI,
As of now, I am generating pdf from the recipe, not from the publishing rule, do I have to switch to the publishing rule.
if yes I hope it should not impact on pdf quality right?
Gourav Upadhyay
So its a PDF representation, not HPGL?
As far as I know, the AfterEDRloader only controls how the "Additional Files" are identified. The publishing rules are going to say what "extra" files are being published - including PDF's
When you right click on the representation in the annotation view, are there any "Additional Files" ?
Here is the AfterEDRloader.java updated to use Number instead of File Name.
Rename the file to remove .txt
